WHERE TO BUY OIL FILTER TOOL???
FM696969
Post by FM696969 »
i need to change my oil filter, any cross/over tool?
where do i buy one?
GeoffJ
Post by GeoffJ »
I bought mine from a Harley dealer. Fortunately, the same wrench fits my BMW and Harley. When you go to the store, take the filter with you to ensure you get the correct size wrench. Most Pep Boys sell the wrenches. You will pay 2X more if you buy one from a BMW dealer.
'96 BMW R1100R
'05 HD Electra Glide Ultra Classic
popgazer
Re: WHERE TO BUY OIL FILTER TOOL???
Post by popgazer »
FM696969 wrote:i need to change my oil filter, any cross/over tool?
where do i buy one?
PepBoys, Autozone, Kragen etc. Just get the right size as recommended above.
Nobody is sure perfect, but she practiced tirelessly !
Boxer
Donating Member #: 2
Post by Boxer »
I just bought one at NAPA...Buuutttt! The problem with these, is often they are made for a variety of filter sizes and the top part will not go all the way up into the recess around the filter and the bottom part is the part that needs to grip the filter.
The one I got is a very sturdy steel wrench with a 3/8" ratchet hole to turn it with, but I took it home and cut off the top half that I didn't need. Now it fits neatly around the bottom end of the filter.
VABeachBMW
Post by VABeachBMW »
Once you get the BMW filter off, you may want to try the K&N oil filters. Best feature is the 17mm nut on the bottom for easy removal. Favorably reviewed in the oil filters exposed article (buried in the archives of IBMW riders forum, I think). :wink:
ebiker
Post by ebiker »
GeoffJ wrote:I bought mine from a Harley dealer. Fortunately, the same wrench fits my BMW and Harley. When you go to the store, take the filter with you to ensure you get the correct size wrench. Most Pep Boys sell the wrenches. You will pay 2X more if you buy one from a BMW dealer.
The German made BMW oil filter tool will probably last your life time and eventuality be passed onto your grandson to become a conversation piece.
So, why not spend the extra $$$$.
Ed..
I'm outta' here!
Post by CycleRob »
Look for one labeled "76mm 14 flats" that doesn't flare out too large from the I.D. so it will fit up inside the filter tunnel. I was fortunate that mine fit perfect. It was around $5 at an auto parts chain store.
Anger
I made one out of a coffee can today
Post by Anger »
Doing maintenance on my new to me bike. Necessity dictated some fast thinking. I made one out of a coffee can, cut top/bottom off, rolled it tight. Lined the inside with duct tape. Inserted it around the filter and used a normal oil filter wrench to apply the pressure. I'll probably purchase the BMW tool but this solution worked for me in a pinch.
2008 R1200R
2002 R1150R For Sale http://forsale.engineeringpros.com/r1150r/
2009 Triumph Bonneville
GeoffJ
Post by GeoffJ »
Ed..
You're kidding, right?
'96 BMW R1100R
Anger
Post by Anger »
Three (3), count 'em, three autoparts stores today and NOTHING. I'll keep trying. I'm too cheap to buy a genuine new BMW tool when the same functionality can be had for $4.00.
CycleRob wrote:Look for one labeled "76mm 14 flats" that doesn't flare out too large from the I.D. so it will fit up inside the filter tunnel. I was fortunate that mine fit perfect. It was around $5 at an auto parts chain store.
2008 R1200R
GeoffJ
Post by GeoffJ »
Anger wrote:Three (3), count 'em, three autoparts stores today and NOTHING. I'll keep trying. I'm too cheap to buy a genuine new BMW tool when the same functionality can be had for $4.00.
Try checking the tool section in a Sears store.
'96 BMW R1100R
Boxer
Post by Boxer »
Anger, go ahead and spring for it. I have gone through 3 aftermarket/generic oil filter wrenches in three years. They become "rounded" out, or they won't fit up into the filter cavity well, or in the case of my last acquisition, after cutting the top part off, it now will not fit the filter correctly at the bottom. I gave up and just bought the damn BMW wrench for $19. It was a frustration purchase!...and it has the same 3/8" socket hole and big wrench nut at the bottom as that other one mentioned. And years from now I can tell my grandchildren about it as it hangs up there on the wall...
stig
Post by stig »
surely.... buying good quality tools ( BMW tools) to work on your BMW is a reflex not a debate, as the first time you use it, it has paid for it's self :!:
orbea54
Oil Filters
Post by orbea54 »
Along the lines of oil filters, do you have to use a BMW oil filter or is it the same as a car filter that can purchased at a parts store?
GeoffJ
Re: Oil Filters
Post by GeoffJ »
orbea54 wrote:Along the lines of oil filters, do you have to use a BMW oil filter or is it the same as a car filter that can purchased at a parts store?
I'd stick to the BMW filter for quality purposes. I'm not sure how well aftermarket filters are constructed or the quality of the filtration.
Now, the $5 aftermarket oil filter wrench I bought six years ago is a bargain compared to the BMW tool. Why pay more for something you'll use so infrequently?
'96 BMW R1100R
Post by Doug »
ride1150r
Try this
Post by ride1150r »
Try here, drive to this place, look over there, drive to sears and then to the auto parts store. $40.00 dollars in gas and 20 hours later, you saved $14.00 dollars. Spend the extra money, keep your local BMW dealer in buisness so they don't close like so many dealers have.
Just my opinion
scott
Anger
Post by Anger »
3 auto parts store AND sears all on the main road I take to go home. Extra gas, zero, extra time (no more than I'd have spent watching TV). Saving $14, priceless. If I have to, I'd probably mail order the part along with a couple extra bits and pieces from Chicago BMW which saves me gas money making a trip across town in heavy traffic. I'll mail order the tool as a last resort if Sears doesn't have it tonight on the way home.
Anyone have a BMW part number they care to donate to a fellow R1150R rider
I know, I know, if I went to the local shop, I wouldn't have to know this information. Thanks, please drive thru.
2008 R1200R
Anger
Post by Anger »
Well, Sears was a no-go. All they had was the standard metal strap and three-prong concentric reducing clamp that I didn't want to mess with. My theory is that Sears is now another Kmart.
Anyone with a BMW part number out there? I'd like to order one from Chicago BMW with some other maintenance items.
2008 R1200R
Deano
Post by Deano »
