good morning all, and thank you for all of your input
i was just wondering if anybody makes an oil cap with an temperature gage
integrated ,so you could look at your left cylinder in warm weather and find out how hot your running,it would seem a good idea to me
thank you
I don't know about an oil cap temp gauge...haven't seen one. I bookmarked this link though and hopefully will be doing this mod in the next couple months: http://home.mindspring.com/~jabrooks/tech/oil_temp.htm Haven't decided whether to go digital though or the clock replacement route...
no man that's not what i'm talking about
what i mean would be unscrew your filler cap (oil)
and replace it with a temperature gauge
end of story, analogue that is
a thermometer the size of our filler plugs
very simple ,i cant beleive it's nor accessible allready
thanks for taking the time to reply
maybe i'll make one ......! (try anyway)
talk to me man
Pierre
Should you go ahead and make one, you'll find out why one does not already exist. That filler hole plug only plugs a convenient hole for adding engine oil. The oil is actually in the engine, the oil coolers, and the sump, all of which are separated from that filler opening by a lot of engine stuff.
thanks man for the insight
yep it just look too good to be true
and i'm glad to hear the reasonning from you
sotr of makes me feel at home
hey ,i hope i get "E" for effort
thanks again
Pierre
You get an 'E' for effort and an 'I" for imagination. But whatever you do, keep those imaginative thoughts flowing. Didn't Galileo try thousands of compounds before he made the light bulb work?
mac
(That was a joke, Ladies and Gentlemen. I had been looking for an excuse to mention Galileo ever since I heard his name mentioned over the weekend in reference to motorcycles. But I'm not allowed to talk about that.)
Good idea, but what would you expect to read. The temperature will not be reprersentative of the engine or the oil since is not in contact with either, the only thing you will see is the temperature of the air in the valve cover............and may I ask, how can this be of any help to you?
No offense intended, just trying to save you some time and effort....
ok thanks had my wires cross
i'm going to put the drill down now and take the shavings out of my engin
thanks boxer
well you cant screw up if you do nothing......
and machew i know how much you want to use Galileo" name
but everybody knows he invented the tulip bulb,not the light bulb
check it out .......
If you really want to check the oil temp, which BTW, is not a bad idea. Do a search on Cyclerob's installation of his temperature gauge. That is one of the cleanest installations that I have ever seen, and is not too expensive.
If you can't find it, PM him, I'm sure he will oblige.
