So I ordered the Wunderlich Engine Guard so I would have a nice place to mount my PIAA lights and a nice foot rest for longer trips and the added protection. I have always had good luck with with Wunderlich products but this guard was the exception. The front guard mounts to three point and I was amazed how far off the right top points was. Looking at the bar laying flat on the floor I could clearly see the tubing on the left and right side were not bent at the same angle. There's no way I could bent this bar by hand and it was not close enough to be able to draw it in with a long screw so I had to break out the torch and heat the tubing to get it to the proper shape then sand and repaint the guard. I wish I would have taken a picture of the guard while it was laying on the floor but I was concentrating on fixing the problem. I suppose I could have sent it back for a new guard but being a pretty handy person and I decide to fix the problem myself. I'll call Santa Cruz BMW Monday and let them know what happen so they can check there stock.
Left top mount
Right top mount (way off)
bottom mount
I put a Wunderlich guard on my R-bike about a year ago. I had to leave all bolts loose until all the bolts were installed because the alignment was so bad. However, it all tightened up nicely in the end. I am disappointed in the paint which seems to chip off with the slightest rock or gravel ding. It is a nice mount for the PIAA's and protected the rocker cover when I dropped the bike in a parking lot at very low speed. I was wondering if you can still get the plastic protectors which go on the bars.
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
I have not seen plastic protectors listed anywhere on their website. You might be able to get the clear 3M protective sheet and cut off what you need. My local BMW dealer carries it by the sheet.
As far as drawing the guard in with a screw, the supplied screw would not have been long enough and the alignment was so bad I don't think a longer screw would have lined up well enough to start it.
I had the same experience when installing the crash bars a few years ago. Everything was fine once all the nuts and bolts were tightened.
Yup. The paint scrapes/chips a lot easier than it should for a $369 item. Just dump the bike once, and you'll be happy you installed this ugly, expensive, yet very practical leg rest.
The plastic crashbar protectors are on page 260 of the Wunderlich catalog. The part number is 8600435 for the pair.
Anthony
Member since Dec '03
2003 BMW R115RT-P
2006 H-D FLHPI
